02-03-2022 05:17 AM
I have my Nest doorbell (battery) plugged in (using the chime). In the home app it shows it is plugged in but after a few days, it shows the battery is low and finally it stops working and asks for charging. The battery usage setting is in "balanced" mode. The chime has the specification that google asked and when it is connected to the chime it works with no problem and the app shows the doorbell is plugged in!
Any idea what is wrong?
02-03-2022 08:56 AM
There are many customers reporting problems keeping their Google Nest Doorbell (Battery) charged, especially when the temperature gets to around 32 degrees Fahrenheit (0 degrees Celsius), which is well within its stated operating range. The thread below has over 500 replies. We were thinking of buying one of the battery doorbells until we saw this thread, and so instead bought another Google Nest Hello Doorbell.
05-02-2022 05:38 PM
We hope you were able to get the help you need but if you're still having trouble, you might want to check out this link for additional information.
If the issue persists, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Archie
