10-06-2021 06:35 AM
Hello
I have just wired my nest doorbell (battery) since the successful installation by an electrician, it only picked up one movement. Hours since, though i tried approaching the camera, nothing has been recorded at all, let alone sends out any alerts to my phone.
Ive triple checked the events and all are enabled which inc. The push notifications.
Why ????? Please help ...
11-17-2021 03:27 PM
Hi all sorry for the late response. It turns out that fact. Reset the device helped. However do notice that for some odd reasons, straight after this was done, the sensitivity level of the device wasnt the best and slowly over the coming days improved. Unsure if its just a placebo effect or indeed Google Nest devices have some sort of intelligence that needs to be trained over time !
The similar issue re occurred again after i ended my nest aware subs. I refact reset again and it did the learning the same way again and ended up picking up its game after a few days.
Odd, but this happened 2x and i did the same fix that took some learning time and its all permanentlt good now.
Maybe it has some active ML feature that indeed needs training depending on environment, etc. ?
10-10-2021 02:44 PM
Hi, I am having the same problem. My Nest doorbell was working well for a few weeks, now do not receive notifications & it does not record.
10-19-2021 11:39 AM
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I can definitely understand how frustrating your situation must be. I would love to help you find a solution to this issue.
11-17-2021 12:52 PM
Hi, RamaIndrawan.
I just wanted to jump in real fast to see if you saw Brad's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
11-17-2021 01:08 PM
Hi thank you I think we may know the issue & it is not related to the device.
11-17-2021 03:05 PM
Thanks for the update, TanLou62. Hopefully everything gets sorted out well for you. Let me know if there's more you need, however.
Thanks!
11-17-2021 03:27 PM
11-18-2021 11:44 AM
Hey there, @Ramalndrawan.
Thank you so much for bringing this up to my attention! There definitely is a learning factor built into the AI that works like Familiar Faces for example. Granted; this is available with a Nest Aware subscription, but the AI is still there. I will go ahead and submit this feedback forward for you. Thank you for all of your patience.
Please let me know if you need further assistance on this issue.
11-19-2021 12:06 PM
Hey Folks.
