Nest Doorbell Battery making noises when watching live
GJessie70
We just installed our Nest Doorbell Battery, hardwired, and it is making sounds as if it is being touched or rubbed, not really a popping or crackling, when we watch live on our cell phones. There is no wind, no one around, and it's night time. Any idea what could cause that?
GJessie70
Today it's been offline most of the day... Or camera not available... Starting to think purchasing this was a mistake 🤬
EmersonB
@GJessie70 It's us again. How's it going with your Nest Doorbell? Were you able to perform the suggested step above? Also, were you able to check your actual Nest Doorbell and check if there's anything that would make it sound like that?
Keep us posted.
I appreciate the help, Brad.
EmersonB
Hi GJessie70,
