01-02-2023 02:57 PM
Is anybody else having issues with Google home? I got a new gen 2 wired nest doorbell. Ever since I downloaded home, it has been messing with my phones audio. It glitches the audio of any video I watch. When I go to lower the volume it keeps going up and down by itself. Please help.
01-04-2023 02:07 PM
Been having the same exact issue with no idea how to fix it. Along with the sound messing up, it also messes my phones microphone. No idea what to do.
01-04-2023 02:22 PM
I figured mine out. Do you have a smart watch. As soon as I take my watch off Bluetooth it fixes everything. Maybe this will work for you.
01-09-2023 08:35 AM
01-09-2023 08:45 AM
We should not have to restart our devices after checking our doorbells, every single time. Nor should we have to clear cache, clear phone memory, and/or turn off bluetooth to reset the doorbell audio problem.
01-09-2023 08:53 AM
Restarting your device is not the same as a factory reset, but it is definitely the first suggested action if your device isn't working as it should be.
01-13-2023 07:59 AM
@Sisterkake we got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. If you have any questions or concerns, feel free to create a new thread as I will be locking this thread after 24 hours.
I appreciate the help, Brad.
01-09-2023 07:20 AM
I am having the same issue, either I have to restart my phone or clear the cache in the Google Home app and clear memory on my Samsung 21 Ultra. If I'm in my truck and check my battery operated doorbell I show a call on my truck display that I cannot disconnect from. I cannot use my voice to text, nor can I watch any videos because the audio is messed up. I turned off my bluetooth and then turned it back on and everything seems to be back to normal. Hope the fix the problem in the next update!
01-09-2023 09:01 AM
I do know the difference between restart and factory reset thank you. I have to restart my phone after I check my doorbell, every single time. So if I check my doorbell three or four times a day I have to restart my phone every single time because there is something wrong with the app. The microphone or something stays open on the home app not allowing my audio to function properly on my phone
01-09-2023 09:07 AM
You shouldn't need to restart it that often, but if you're experiencing multiple concerns, then I would ask for you to please fill out this form, and a higher tier of support will reach out to you once it has been filled out and submitted.
