Nest Doorbell Battery model
FrancisT27
Hi everyone. I have correctly installed my unit and the camera, chimes, and external audio work perfectly. However, I cannot talk back to the person at the door. I can hear them, they can't hear me. Please can someone help?
I'm running Google Home android.
Cheers.
EmersonB
Hello everyone,
@FrancisT27 aside from restarting your Nest Doorbell, check if your permission to your microphone is enabled through the Nest app or Google Home app. You can check this on the settings of your mobile phone. Also, try to record your own voice through your default voice recorder app to check if your mobile phone's microphone is working fine. Hit this link for more information.
I appreciate the help, Brad.
EmersonB
Hi FrancisT27,
