Nest Doorbell (Battery) won’t power on
JLCormack
Doorbell (battery) that was also hardwired went offline randomly one day. Could not resolve so decided to remove and readd the device. Took it off the mount to plug into charging port and reset… it won’t charge. Tried reset button. Tried multiple chargers. It simply will not power on if it’s hard wired or utilizing the charging port. Device appears completely dead out of no where.
8 REPLIES 8
MrVacca
Silver Product Expert
Yikes, that is not good. I'm sorry to hear about that @JLCormack - it sounds like you've tried everything under the sun.  Is there any chance it's still under warranty?
I tried the warranty form online and it won’t submit says error. Any advice? It’s certainly around 1 year old. Has been in a weather proof case too.
MrVacca
Oh man, it sounds like the warranty might be up. The limited warranty from Google is 1 year 😞 Sorry to be the bearer of bad news but if it's past that, you might need to buy a new one. Sorry I can't offer any other troubleshooting tips.
@JLCormack
There are ongoing complaints in this forum about the warranty page not working.
You could try contacting Google Nest Support to see whether they'll replace it, starting with this link:
https://support.google.com/googlenest/gethelp?hl=en
aatienza
Oh no! I'm sorry to hear that. Let's check this further — could you fill out this form and let us know once you're done?
I appreciate the help, MrVacca and MplsCustomer.
Archie
JenniferV
Hello JLCormack,
We haven't received your form — we're you able to fill it out?
Thanks for the help here, MrVacca, MplsCustomer, and Archie.
Jennifer
janthadeus
Hey everyone,
I'm checking in to see if you are able to fill out the form. If not, please do so, so we can assist you further with your concern.
Thanks for the help here, MrVacca, MplsCustomer, Archie and Jennifer.
janthadeus
