03-17-2025 07:48 PM
I’ve had a nest doorbell since about 2018/2019. It usually works fine but I noticed the chime stop working. I had a electrician come out and reinstall it. Chime worked for a little now the door bell is offline and there is an annoying buzzing sound coming from my chime box. Any suggestions ?
03-21-2025 03:59 PM
Hi Patt625,
Thank you for posting in the community. I'm sorry to hear you're experiencing trouble with your Nest Doorbell making a buzzing sound. I understand how frustrating that can be, and I'm here to help.
To help us troubleshoot effectively, could you please answer the following questions:
What exact model of Nest Doorbell do you have? (e.g., Nest Doorbell (Wired), Nest Hello, Nest Doorbell (Battery) wired)"
When you say the doorbell is 'offline', is it completely inaccessible in the app?"
Have you tried restarting your Wi-Fi router?
Have you tried restarting the Nest Doorbell itself?
Is the Nest Doorbell receiving power?
Did the electrician who reinstalled the doorbell specify what they did during the reinstallation?
Did they replace any wiring or components in the chime circuit?
What type of chime box do you have? (e.g., mechanical, digital)
Is the buzzing sound constant, or does it change in intensity or frequency?
Beyond the electrician's work, have you tried any other troubleshooting steps?
Please provide your responses to these questions. I look forward to hearing from you and helping you resolve this issue.
Kevin
