10-28-2024 03:22 AM
I have a nest doorbell (gen 2 battery) and have had it for a while. Usually the battery lasts a week.
I have installed a power supply to this and noticed that the doorbell still needed charging after approximately 2 weeks. I had hoped that it was now a fit and forget solution but it seems not.
I have experimented with the settings and discovered that clip length and resolution do not significantly affect the power usage.
However having a zone setup does. This seems to drain the power so much the power supply cant keep it topped up.
Why is this happening? Ive reset several times and re added to the home environment.
Does anyone know if this is an issue with the wired doorbells from the states? and do those record 24/7?
10-31-2024 02:46 PM - edited 10-31-2024 02:49 PM
Hi Andybrad,
Thanks for posting in the community!
I'm so sorry to hear that your Nest Doorbell's battery is draining quickly. Don't worry; I'm here to help! Just to get started. I'd like to confirm some information with you. Can you please help me answer the next questions?
In the meantime, if you have any further questions, please don’t hesitate to reply to this post. I'll be happy to assist you further!
Nery.
