02-01-2022 02:27 PM
Nest door bell had been working for over a year until I switched the On/Off switch in the app to turn off the indoor chime. When I switched it back on it would no longer work. Has anyone had any problems with the little relay that gets plugged in on the mechanical chime? Everything else seems to be working, camera, wifi, and the mechanics of the chime work fine as it rings when the wires are shorted together.
04-29-2022 09:31 PM
Hey Duffman87,
We hope you were able to get the help you need but if you're still having trouble, you might want to check out this link for additional information.
If the issue persists, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Archie
