03-30-2024 01:03 PM
Please help.. I know there are bigger issues in the world than connecting a doorbell!
I have fibre broadband to my house and an ofnl modem. I have 2 Google WiFi nest pro routers.. all working great. I set up a google thermostat and nest audio speaker this week no problems. Each to the nest app and home app.
but the doorbell… it just won’t connect to the nest app! I’ve reset and restarted everything, code nc009 indicates a WiFi issue, but I can’t work out how to change firewall settings on my router.. typing my IP router address into the web takes me to the download the home app page..
I’ve followed each troubleshooting guide, received a replacement doorbell but all to no avail…
03-31-2024 11:15 AM
Hi @JQ5,
answering your question,
There are actually limited security setting adjustments available directly on the Nest Wifi Pro itself. However, you can manage some key security aspects through the Google Home app. Here's how:
Change Wi-Fi Security Protocol:
Enable WPA3 Transition Mode (if available):
Important Notes:
Additional Security Measures:
While the Google Home app offers limited direct security configuration, here are some additional practices to enhance your Nest Wifi Pro network's security:
By following these steps and practices, you can improve the overall security of your Nest Wifi Pro network. If you have more advanced security needs, consulting with a network security professional might be recommended.
Mario.
03-30-2024 02:01 PM
Hi there!
Thank you for posting. I'm sorry for the experience you're having with your doorbell. To make sure we're on the same page, do you have a 2nd generation or 1st generation doorbell?
If you're connecting your doorbell to the correct application and you're still having the same error, here's a link where you can perform a reset or factory reset on your device. Follow the steps depending on the doorbell you have: Restart or factory reset Nest camera or Doorbell Restart or factory reset Nest camera or Doorbell
Sincerely,
Obed
03-30-2024 02:54 PM
Hi Obed, thank you for your message. I’ve just bought the doorbell from google store and it is the only available doorbell, I’m assuming it’s 1st generation as there isn’t an alternative. I have tried and tried to connect it via the home app and nest app but it doesn’t connect. I think it is a WiFi issue? I need to know how I can change my router security?
03-30-2024 04:19 PM
Hello jQ5,
I appreciate the efforts you've made to connect your doorbell to Google Home and Nest App. It would help me a lot if you could share a photo of the doorbell and its status light.
Let me ask a few questions:
Also, if you're experiencing internet connectivity issues, please contact your internet service provider.
Obed
03-31-2024 12:33 AM
Hi Obed, thank you for your continued help. My internet and WiFi are working perfectly. I installed a nest audio this week with no problems via the home app. I can’t share a photo on this chat? But I have the latest nest wired doorbell from the google store if that helps.
I have tried every trouble shooting flow displayed in the interactive help and speaking with the support team.. my question is, how can I change the security settings on my nest WiFi pro?
03-31-2024 11:15 AM
Hi @JQ5,
Important Notes:
Mario.
04-02-2024 01:59 AM
thank you so much for your replies.. I have a partial result! I have installed the doorbell on a new space on the nest app and google home, it’s now working.. only issue is that it’s not in the same home as my other devices, but I can live with that:)
04-02-2024 09:07 AM
Hi @JQ5,
Great news that this inconvenience is resolved! If you have any other questions, feel free to start a new thread and we'll be happy to assist you.
Obed
