05-08-2024 06:36 AM
Hello All,
The floodlights on my Nest Cam is hyper sensitive and is pretty much always on.
This is my second post (first one got locked by the time I was able to respond).
I have factory reset the system twice, uninstalling and reinstalling. I've also delved into the settings to try and adjust the sensitivity, but it doesn't seem to make any difference.
On somewhat of a personal level I'm not too fussed, as the camera seems to be unaffected & these lights face away from my house, but trying not to annoy my neighbnours!
Any advice greatly recieved!
05-11-2024 10:46 AM
Hi @ajones164,
That sounds frustrating. Let's get those floodlights under control. Here are some steps you can take to address the issue:
Additionally here you can find a helpful article that can help you to use the Home app to customize your Google Nest floodlight settings.
Additional Tips:
By following these steps, you should be able to reduce the sensitivity of the floodlights and minimize any inconvenience caused to your neighbors.
Please let us know if you were able to fix it and if you have any questions or need further assistance.
Josh
