05-08-2024 12:10 PM
I have an out of warranty Nest Cam IQ Outdoor that has stopped working.
I think the power cable is faulty and needs replacing.
is it possibly to purchase a replacement cable and the tool for removing the camera from the mount?
Thanks
Chris
05-11-2024 12:54 PM
Hi ChrisNZ,
Thanks for posting. That's a great question.
Unfortunately I've checked cables for Nest cam IQ in the google store but they are out of stock, and since your camera is out of warranty, we can't send you a replacement directly. However, you can try searching for compatible cables online or at electronics stores.
if you have any other comments feel free to reply to this post.
Jonathan
