01-26-2023 07:01 PM
I installed the doorbell and everything works properly. The only issue I have is that the mechanical chime won’t ring when the nest chime connector is installed.
Without the connector it’s working perfectly.
Question 1: Can I run the system without the chime connector (because this way it works as it should)
Question 2: If not, what are the suggestions solving the problem. I already did all the troubleshooting here from the blog and within the app.
thank you for your support!
Mike
01-27-2023 08:15 AM
You could check whether your doorbell transformer is adequate:
https://support.google.com/googlenest/answer/9247132?hl=en-GB
You could also check whether the chime connector is wired correctly:
Nest Hello:
https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Wiring-diagram/m-p/24455
2nd Gen Google Nest Doorbell:
01-31-2023 10:17 PM
Hey Coralu,
I want to check if you still need help. Don't hesitate to reach back if you do.
I appreciate the help here, MplsCustomer and Emerson.
01-28-2023 03:16 PM
Hello everyone,
@Coralu thanks for reaching out and for sharing with us your issue. We would recommend you check the links that MplsCustomer has shared, for the required power and voltage for your transformer. If you run your system without the included chime connector, we're not sure how long it will last. Let us know if you have more questions.
02-01-2023 01:18 AM
Hi, thank you for your suggestions. Unfortunately i couldn't make it work. The chime works perfectly with the Nest Doorbell without the connector. I might change the the doorbell chime.
Thank you all 🙂
Mike
02-01-2023 11:25 AM
02-02-2023 11:49 AM
