11-18-2024 09:18 AM
Installed Nest Hello Wired doorbell in 2021 and connected it to inside chime. Everything worked fine until recently and now the inside or outside chime does not ring consistently. The camera sends notifications and works fine but unless I see notification on phone I don't know someone is at the door most times. All wiring looks good. Have increased home duration but doesn't help. Anyone having similar issues and if so how did you get it fixed?
11-21-2024 03:48 PM
Hi @kml1957,
Thanks for posting here in the community. I'm sorry to hear your Nest Hello chime doesn't ring consistently. I'm happy to help!
To better understand the situation, I'd like to ask a few questions:
In the meantime, let's check this tip:
Check if Quiet Time is enabled. This should be turned off.
Keep me posted.
Melany
