02-09-2023 08:40 AM
I had a replacement unit due to a previous fault and am getting less than a week from the battery. The previous unit only lasted about 3 weeks before needing charging. It is also constantly going offline.
I've tried to persevere but it is clearly not fit for purpose. Hoping to get a refund as I'm going to move to a Ring doorbell which actually work as intended.
02-13-2023 09:39 AM
I can imagine this has been stressful for you, and I would like to look into this further. Please fill out this form, and a higher tier of support will reach out to you with next steps.
As a side note; we unfortunately do not offer replacements for parts. If your device is no longer under warranty, we aren't able to offer a replacement.
02-16-2023 09:45 AM
Thank you for filling out the form I sent. You should hear back from support very soon if you haven't already. Once they are in contact with you, they should be working with you moving forward with this inquiry.
02-20-2023 07:15 PM
Thanks for the help, Brad.
