Nest Hello wired - 4 cable chime
Marjak
I'm trying to install the Google Nest Hello with chime with 0123 labels for which the instalation is not supported in the app. There are 2 blue and 2 red cables and don't know where the chime connector should be connected to. I've attached photo and would be grateful if someone could help.
aatienza
Hey Marjak,
We hope you were able to get the help you need but if you're still having trouble, you might want to check out this link for additional information.
If the issue persists, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Archie
