Nest battery doorbell reinstall
Lizbet
6 REPLIES 6
I am terribly sorry to hear that you're having this issue! I would love to assist you with this issue. If you are having issues with your Nest Cam or Nest Doorbell, I would suggest that you first start by restarting it.
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
aatienza
Hey Lizbet,
I appreciate the help, Brad.
Archie
Lizbet
still not sorted as I keep getting the message something went wrong.
Betty
janthadeus
Hey folks!
Thanks for your help Archie and Brad.
i'm sorry to know that but thanks for trying. No worries, we'll check this out. What’s the color of the LED status light? Has the device been paired before? Can you connect to the internet with other devices? How far is the device from the router? Also, are there any other devices that experience issues with the Wi-Fi?
Best regard,
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
