10-02-2021 05:09 PM
Just bought a nest cam (battery) arrived last night. I cannot get it to charge. No white light. In app an infinity symbol is showing. (Have tried different outlets / checked that it is plugged in correctly)
Would really appreciate some advise
10-03-2021 05:07 AM
Hi @tracmurp
Are you getting a blue light when you plug the camera into the charger?
10-05-2021 01:10 AM
Apologies, I thought I replied and can’t see the response in the chain. No blue light (green light when camera is on is the only light)
10-05-2021 09:22 AM
Hey folks.
Just popping in to see if you still needed assistance with this issue? Please let me know!
11-16-2021 02:11 PM
Hi, everyone.
Thanks
10-05-2021 08:57 AM
Yikes, sounds like something is def. up with your device. Have you tried doing a factory reset? You press the button on the back using a paperclip or pin until you see a solid yellow light.
