11-24-2023 04:21 PM
I don’t have a ground wire from my junction box.
Can I install without the ground wire?
if not, some people said the junction box metal is grounded, so how do I check the junction box is grounded?
How to install nest cam with floodlights without ground wire? (Please provide with a clear detail because I am a layman)
11-26-2023 06:20 AM
Yes, it can be installed without the ground wire.
To check if the junction box is grounded you'd need to connect an AC voltmeter between the junction box and a point of ground reference, like a pipe in the earth or a wire buried by the utility company, telephone company, or cable company. Be sure that the earth ground contains moisture.
If you're at all unsure, I'd recommend consulting a local qualified electrician.
