12-03-2022 06:47 AM
When I first install the best cam, everything went like clockwork. 2 weeks in and my broadband provider upgraded my WiFi to full fibre and a new router.
I have reconnected my display hub Google nest WiFi without issue but the cam will not reconnect
I've rest the cam, reset the router, uninstall home app and reinstalled. Checked network, changed network, deleted network and reinstalled. Every time the same. When it trys to connect it comes back with the same message, "can't connect, try moving closer"
Someone please help before it gets launched.
12-06-2022 10:58 AM
Hi Hadenough,
Thanks for reaching out and sharing with us what you've done. Let's see what's going on. To confirm, did you reset your Nest camera to the factory default or you just perform a simple restart? Do you have the battery or wired Nest camera?
Give these steps a try:
12-09-2022 12:37 PM
Hello Hadenough,
How's it going with your Nest camera? We would appreciate it if you could share with us the information I'm asking above. Also, were you able to perform the steps I'm suggesting? I'd be glad to hear from you — I'd like to make sure everything is working.
12-11-2022 05:36 PM
I just wanted to jump in here to make sure that you saw our response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
