10-30-2021 12:18 PM
One of my Nest cameras keep going offline repeatedly. The blue light is blinking slowly. I’ve tried unplugging, resetting network, etc. can’t seem to keep it working. My other camera and Nest doorbell work just fine. What is the problem?
10-30-2021 01:01 PM
YOUR CAMERA IS TOO FAR AWAY FRO. YOUR ROUTER.
10-30-2021 01:38 PM
I appreciate your response, however, it is closest to the router than my other camera or doorbell. It is approximately 20 feet from the router.
11-18-2021 12:33 PM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be, but I wanted to make sure that your issue was addressed. Do you still need help with this issue? I know that there's been a delay in response since you posted. It does sound like it's connected to a wifi/internet issue. Id suggest that you restart your cameras, your wifi, and then try again to see if it is staying online. If the signal is weak, try using a wifi extender possibly.
11-23-2021 09:51 AM
Have a great day!
Eric
11-24-2021 09:27 AM
Hey Folks.
