03-16-2024 09:58 AM
My camera reached 153 degrees f (67 c), inside, in a 70 degree f house.
Is this normal or should I be concerned about the safety of this in my home?
03-17-2024 04:08 PM
Hello, I don't think this is normal. I'm going to try and escalate this so that you can speak with an actual Google Tech person. This area is just a user forum. Once you find out more please return here and let us know how it went.
04-04-2024 12:42 PM
I'm sorry you're running into this situation with your Nest camera. I know how frustrating it can be when your security system isn't working as expected.
I understand that since the camera was moved, the temperature is currently over 100°F, which is slightly above the recommended operating range for Nest Cam Indoor (32°F to 104°F).
For safety reasons, I highly recommend turning off the camera immediately to prevent any potential damage. I would like to know if the camera still reaches 153°F.
Keep me posted,
Melany
04-05-2024 11:17 AM
Hey,
I unplugged it for a bit and plugged it back in. Since then I have been monitoring and my camera has stayed well below 153.
All three of my nest cameras run a bit hot, but I think that's just normal for them.
Thermal images linked of all three. The first image shown is the camera that had at one point reached 153
https://photos.app.goo.gl/u6PrqwGUARQbzXLy5
03-17-2024 06:39 PM
Thanks! Will do
03-17-2024 07:12 PM
Thanks for bringing this to our attention. A few questions: do you see any messages or codes in the app? In what area is your Nest Camera installed? Make sure you use your camera in the environment it was designed for.
Please check these tips below on how to keep your camera or doorbell cool:
03-20-2024 09:30 AM
Hey,
I did not see any error codes in the nest app, but a few days prior I moved the camera a few feet and after that the night vision stopped working for a night.
The camera is inside in a room. Either sitting on a dresser or the floor and not in a place sunlight could hit it, or near any other heat source.
It was and is in a well ventilated space, without any containers, covers, or skins.
I unplugged the camera for a bit and since then the temperature has stayed lower, often slightly over 100f.
04-04-2024 01:27 PM
@gmelanymelissa I don't know where you got your temperature numbers from but the original post said it was in INDOOR camera inside a home at 70 degrees. If this is the case then can't you just stop making this person jump thru hoops and offer to replace the camera?
04-05-2024 10:39 AM
Thanks for your help. @EmptyNester
@lowtoast Since your Nest camera isn't working, I'd be happy to help! You can contact us through this form.
Give me a shout if you have any questions.
Melany
04-05-2024 11:40 AM
Thanks Melany,
I think that's the contact form I tried before posting here.
The rep I talked to said it was normal, but, I had a feeling we were not understanding each other and he thought it was in direct sun or in a hot room or was confusing f/c or something.
04-05-2024 02:32 PM
Hi Lowtoast,,,, Ummmm, looking at your IR images I don't think you have a "Nest Cam Indoor". You have a very old Nest DROPCAM which will stop working any day now as nest has stopped supporting them all together.
Here is the article....
https://www.theverge.com/2023/4/7/23673165/google-nest-dropcam-nest-secure-eol
04-05-2024 03:01 PM
Thanks for the concern. I have a slightly later version, like this: https://a.co/d/5SYlSgq
04-05-2024 03:17 PM
Wow,,, cool, I had completely forgotten about that version. Thanks for bringing me up to speed on this.
