01-29-2022 06:06 PM
My Google assistant has just started telling me "that mode is not available for backdoor floodlight" when ask it to turn on or off, even though it will turn the light on or off. It was working fine before.
02-04-2022 01:04 PM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be, but I wanted to make sure that your issue was addressed. I would suggest that you Restart your Floodlight, and if that doesn't work then Factory Reset it and that should hopefully fix the issue for you.
04-22-2022 02:27 PM
We hope you were able to get the help you need but if the issue persists feel free to create a new thread, and provide as many details as possible so that others can lend a hand.
James
