Nest cameras and multiple wifi networks
jgates44
I have a large property with multiple wifi networks. I want to set up a camera on a building at a second location on my property. How do I get the camera to connect to the wifi network available at that location? When I set up the camera, it doesn’t let me choose the network. Does it use the network that my phone is connected to during setup? I am using the Home app.
David_K
If won't work by default if the Wi-Fi network name and password are different. You'll either need to make them the same as the first location, or create a separate "home" in the app to put the second camera in. It will then prompt you to select a Wi-Fi network.
David_K
janthadeus
Thanks for your help here, davidking.
I'm dropping by to ensure that everything is covered here. If you have other questions and concerns, feel free to let me know.
aatienza
Archie
janthadeus
I just wanted to jump in here to make sure that you saw our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Thanks for dropping by Archie.
