03-13-2024 07:03 PM
I have two nest cams that are consistently failing to come out of Night Vision mode. Both cams are 2 years old. I have reset each to factory defaults, updated software, and the issue continues to happen. The issue started in winter, the cameras are in cold weather in Massachusetts. When I log in to the cameras using the app and toggle Night Vision off then back to Auto , the color comes back on and stays until the following morning.
If there is no permanent fix, is it possible to generate a routine to toggle Night Vision off then back to Auto every day at sunrise?
03-17-2024 07:09 AM - edited 03-17-2024 10:17 AM
Hi snwombat,
Thanks for posting in the Community and sharing all the steps you’ve tried to fix the issue. I’d be happy to help you with this. Let’s check it out.
Please follow the steps below:
Keep me posted.
Lance
03-17-2024 07:18 AM
Hi Lance. Thank you for your thoughts. I have completed the troubleshooting steps you recommended but the issue persists. To clarify, the floodlight cameras are controlled by the Google Home app, not the Nest app.
The issue seems to be temperature related. When it is below freezing, the cameras stay on Night Vision unless I manually toggle that feature off/on. Otherwise, in normal temperatures they are functioning normally.
Is there a way to automate turning Night Vision off/on?
03-17-2024 10:18 AM
Hey snwombat,
Great catch! I have updated the response above. Going back to your question, night vision isn’t currently listed as one of the supported starters, conditions, or actions. I’m afraid it isn’t possible to create a routine to toggle night vision off and then back on.
However, the team would like to learn more about this behavior. When you get a chance, please fill out this form and let us know when you’re finished. We’ll have someone reach out to you via email from there.
Lance
03-17-2024 01:51 PM
I have completed the form. Thank you, Lance
03-17-2024 03:01 PM
@snwombat, we've received your form—thanks for filling that out. Please keep an eye on your email, as someone from our team will reach out to you to assist you more. If you have questions or concerns in the future, feel free to start a new thread, and we'll be happy to help.
Thanks for your help, Lance.
