08-30-2025 11:25 AM
I got 2 Nest cams off ebay (because the wired ones are no longer available from Nest) but Nest app won't recognize the QR code or manually-entered code. Don't know how to proceed.
09-01-2025 07:12 AM
The Nest app says it does not recognize the QR code whether I try to scan it or enter it manually. I have no idea how the person unhooked the cameras.
08-30-2025 02:35 PM - edited 08-31-2025 07:09 AM
What exactly does the Nest app do when you scan the QR code or enter the setup code?
Did the seller perform a factory reset on the cameras by removing them from their Nest app while the cameras were still connected to their Wi-Fi (the only way to factory reset 1st gen cameras so they can be reinstalled)? Is the status light blue on your cameras, indicating they are ready to be set up?
09-01-2025 07:15 AM
Yes, the light is on and blue, slowly blinking.
09-01-2025 07:12 AM
09-01-2025 07:17 AM
I don't know whether that can occur if the cameras are still attached to the previous owner's Nest Account, but the cameras do need to have been removed from the previous owner's Nest Account.
Are you getting a blue status light on your cameras, indicating they are ready to be set up?
You could try contacting Support:
3. Select your device from the dropdown, click "Other", then click "Next step".
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
09-01-2025 02:51 PM
Thanks. I spent 2 hours with tier 1then tier 2 senior help desk & they still haven’t gotten anything fixed.
