01-09-2022 01:01 PM
Nest door bell does not ring or display on Google HUB when someone rings the bell. I do get a notification on my cell phone and also rings on my cell phone but does not ring or display 9n Google Hub.
01-09-2022 01:55 PM
Was your Google hub setup using the same account as your phone? If it was and it still isnt showing, suggest that you factory reset it and set it up once more using the same account, and all should work as normal
01-09-2022 02:10 PM
I just reset Google hub and it still did not work. Yes google hub and nest door bell are on the same account.
01-09-2022 02:13 PM
on your google hub does the camera show up at all? IE when you click to home control can you see it there?
01-09-2022 02:14 PM
Yes, I can open the bell camera on the Google hub.
01-09-2022 02:17 PM
Is do not disturb on? What about personalized results? if either of these are on then notifications wont appear either.
01-09-2022 02:26 PM
No it's not on do not disturb and is not off on personalized settings either.
01-09-2022 02:38 PM
That's strange for sure then. Would suggest removing both the hub and the doorbell from the home then adding them again and see if that works for you. If not I'm out of ideas here.
04-25-2022 08:48 PM
Archie
