06-29-2024 03:11 PM
I need a chime.
I bought a Nest wired 2d Gen to install in a new house, which is wired correctly for the Nest. I want to use a hardwired mechanical or electric (not wireless, not smart) physical chime that sounds when the doorbell rings, just like in the old days. (Avon calling!) The network guy made a place for the chime to be installed in the hallway. I don't care about being able to speak or hear through the chime itself; I can do that on the app.
I need to buy the chime. What kind, what technical specs, and where to buy it?
Thanks, y'all.
06-29-2024 07:23 PM
Hello, I'm pretty sure any mechanical chime that runs on a transformer with the same specs as the Nest Doorbell will work. 99% of them should work fine. When you buy a chime it normally does not come with a transformer so you will need to get one of those as well. Here are the specs that Google publishes...
Nest Doorbell (battery) | Nest Doorbell (wired) | |
Voltage | 8 to 24 V AC | 16 to 24 V AC (North America) 12 to 24 V AC (Global) |
Power | 10 to 40 VA | 10 to 40 VA (North America) 8 to 40 VA (Global) |
Frequency | 50 to 60 Hz | 50 to 60 Hz |
Hope this helps.
One more thing: I have (3) of the Google Nest Hubs around my house that all DING-DONG when someone pushes the door bell and the image of who is there pops up. I find it really handy.
06-29-2024 07:23 PM
Hope this helps.
06-29-2024 09:54 PM
Thank you for the intel, EmptyNester!
