11-22-2021 09:18 PM
I recently change my router, and can´t connect the doorbell to the google home app, already reset the doorbell with the back button several times, but can't pass the connecting screen, the led light is always white, when plugged through the USB c, cable
11-24-2021 09:46 AM
I am also having this issue
01-05-2022 11:35 AM
01-05-2022 02:06 PM
Thanks, it's resolved, the problem was the button needed to be pressed really really hard in order to reset the doorbell, I don't know if it was only my unit or all units need that kind of force to be reseated, anyway thanks for the response
01-19-2022 11:52 AM
Hey Folks.
