12-28-2022 05:36 PM
I have zones set up, I just received a package. Didn’t get notification of person package. I go outside camera doesn’t turn on. I have to ring doorbell then I get notification. I have known,unknown persons set up. Why didn’t I get notification? Also another problem I’m having, since I added my wife, I receive nothing she gets all the notifications. Shouldn’t we both get them??
01-05-2023 11:10 AM
I am having same problem. Camera worked fine for two months. Now the camera goes idle and I am not getting notifications unless doorbell is ring. Tried resetting but still idle. I should have kept my Ring doorbell
01-05-2023 11:26 AM
01-09-2023 11:07 AM
Brad, appreciate your helpful response.
Mamawolf1500 and Brody, chiming in to ensure everything is good here. Have you had the chance to try the suggestion above? If yes, how is it?
Mel
01-10-2023 11:09 AM
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
