01-24-2022 05:23 PM
I just purchased my first doorbell camera last month. I bought the Nest battery camera doorbell and I'm already having problems. I set the camera to notify me of everything (people, vehicles, packages, animals, etc.), however a lot of times I can be right in front of the doorbell waving my arms and it won't record and other times I will get partial events recorded and then it'll stop before the car, person, whatever, is out of range. Is this a normal thing? I'm assuming not. Is it not recording everything because I don't have it wired? Idk if I should return it? Any advice would be greatly appreciated!
01-24-2022 07:03 PM
Take a look at the settings in the home app. There is one to increase/decrease the overall sensitivity to events, and another to "record more" or something to that affect. It will eat more battery, but it will cause it to capture more pre-roll footage prior to triggered events. Unfortunately, even with it set to most sensitive, and maximum recording it at times not capture an entire event. If the car, person, animal, etc, doesn't keep moving, it will sometimes just cut off the event. It does a decent job most of the time, but it's definitely not perfect. I've found the actual object detection to be quite good overall. I rarely get false events, but sometimes rain or snow will generate false events at night.
With regard to it not being wired, I do believe it will turn down some of the settings by default to try to save battery, but you should be able to override those. If you're planning to keep it on battery, I would recommend that you create zones to trigger just on areas that are most important to you.
02-03-2022 03:07 PM
Thanks for the assistance @firmwaredev. Please let me know if you need more help.
Steve
02-04-2022 06:08 PM
Hey Folks.
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still need assistance, feel free to start a new thread and we'll be happy to help.
Steve
