03-31-2023 12:41 AM
I have connected the Nest Hello (wired) to existing Honeywell. I first connected it to 1 and 3 but this only gave a constant buzz and no Power was given. I changed it as in picture Now and this gave Power. Now Its problem that the indoor chime does not give sound.
03-31-2023 09:12 AM
Do you have the "Electronic chime" option turned on for the doorbell?
03-31-2023 09:41 AM
Yes I do
03-31-2023 10:19 AM
I don't know anything about the Honeywell D3230, but I found this post saying "The D3230 doorbell cannot be used with a Nest Doorbell due to the fact that it has a built in transformer which is only 8V, making it incompatible."
https://support.resideo.com/s/article/Can-I-use-the-D3230-with-the-Nest-Doorbell?language=en_US
And there is this Reddit post, which suggests either bypassing the built-in chime (with supporting description and photos) or removing the transformer built into the Honeywell D3230 (with no specifics).
https://www.reddit.com/r/Nest/comments/rwp48q/nest_hello_wired_works_on_8v_doorbell_honeywell/
I don't know if this is a workable solution.
04-08-2023 07:00 PM
Checking in — I just wanted to make sure if you’ve seen MplsCustomer’s reply. Let me know if need more help.
04-11-2023 07:05 PM
Hey Oivindby,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
04-11-2023 10:39 PM
All Good thanks
04-12-2023 03:15 PM
Happy to hear that! I appreciate the gesture. It looks like we can consider this one complete, so I will be locking this in 24 hours if we won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
