12-30-2023 12:52 PM
Hi Team,
I've had my doorbell for about 8 months now and had to charge it a couple of times, and had no issue putting it back and it was up and running immediately, no issues at all. I once changed WiFi providers and had to perform a reset to connect to the new network but that all worked fine too.
A few days ago my doorbell went offline. I looked in the Google Home app and noticed the battery was below 10%. I figured it was a battery issue. I charged the doorbell to 100% today and tried to connect it back but but it wouldn't. I did a restart as well as a full factory reset. The doorbell comes back on again but in the set up on Google Home it just fails to connect to the device. It asks me to move "closer to the nest doorbell" but I am literally next to it, and so is the WiFi router. I tried various troubleshooting options detailed in an old post I can no longer respond to (link - https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Nest-Doorbell-battery-won-t-connect-dur...).
No luck unfortunately. Please can you help guide me how I can connect my doorbell back up?
Thanks
12-30-2023 06:21 PM
You might want to consider contacting Support to determine whether your battery doorbell has failed and needs to be replaced under the 1-year-warranty, using the link and instructions in this post:
01-03-2024 01:50 PM
Hello Nightingale112,
Oh no! I'm really sorry you're having trouble with your Nest doorbell . Let's get that sorted out! Can you fill out this form with the details? Once you're done, just let me know.
Edmond
01-05-2024 04:53 PM
Just wanted to follow up on that form you were filling out. Did you manage to finish it? If you have any questions or need any help, please let me know.
Edmond
