07-23-2024 11:56 AM
I have a hard wired flood light camera and it was working fine for about 6 months, then it started giving me the low battery alert. I saw something in the forum that stated disconnect it hard reset and reconnect, but now I can't get it to reconnect anymore. The green light is on, the flood light cuts on during motion, but I need it to reconnect to my WIFI and can't. Help!
07-24-2024 08:04 AM
Did you perform a factory reset as described in the Help topic below, pressing the factory rest button until the status light blinks yellow 4 times with a countdown tone, and then turns solid yellow with a confirmation tone?
https://support.google.com/googlenest/answer/9252162?hl=en&sjid=7247967974083017712-NC#zippy=%2Cnest...
If your floodlight camera is connected to power all the time and you're not switching off the camera's circuit, you should NOT be getting low battery alerts. We've had a battery camera (the same camera) since Sept. 2021, plugged in with the optional power cable, and it's been "Live" and online ever since.
If you need to contact Support:
