Nest hub connect to nest doorbell
Mdoddy
Hi
I have a google hub 2nd generation and wondering if I bought the battery operated nest doorbell does it connect ok to it?
Will it chime in the hub and video of who is at the door appear.
thanks
EmptyNester
Silver Product Expert
Hello,  I'm and end user as well.  The answer is yes it should work.  You just have to make sure to turn on the setting in the doorbell to tell it to do that and also in the Google Home app activate the settings the Hub to do that as well.
2 REPLIES 2
EmptyNester
That’s great thanks very much
