01-14-2023 02:33 PM - edited 01-14-2023 03:47 PM
I tried installing the nest wired(2nd gen) door bell today. Once I turn on main power I hear a buzzing noise from the chime and the doorbell has no power. Tying to see if anyone has ideas as to what is wrong
The transformer I have is 16V, 10VA.
01-15-2023 09:38 AM
The possibilities include an incorrectly wired "chime puck", a defective "chime puck" (this forum has numerous reports of defective "chime pucks" for the new 2nd Gen Google Nest Doorbell), or an inadequate doorbell transformer (https://support.google.com/googlenest/answer/9247132).
01-19-2023 08:57 AM
The Nest Doorbell (wired, 2nd gen) must be connected to a transformer rated to 16 to 24V AC and at least 10 VA to receive enough power. 30 VA is recommended for homes that have high-impedance doorbell wiring due to long wire runs or thin doorbell wiring. You may need to upgrade or replace your current transformer. You also need to replace your current Nest chime connector with the new one that comes with the Nest Doorbell (wired, 2nd gen). For more information, check this article.
01-24-2023 10:56 AM
@barru007 how's it going with your Nest Doorbell? Were you able to read the information and check the links that MPL and Brad have shared? In case you have an update, you know where to find us.
I appreciate the help, MplsCustomer and Brad.
01-25-2023 11:24 AM
Hi barru007,
