Nest wired doorbell pro
Onucycle
Do I need to be a Nest certified pro installer ton install these wired units?
2 REPLIES 2
Ashepherdson
It's not required if you are comfortable doing it, and are familiar with your electrical and doorbell systems.  I did mine years ago and it's been perfect ! Just follow the on screen instructions !
@Onucycle
If you are able to replace a conventional doorbell, you should be able to install a Google Nest doorbell. You can find an install video on this Help topic:
https://support.google.com/googlenest/answer/12570869
If your doorbell's transformer does not meet the requirements found on the Help topic below you may need to install a new transformer:
https://support.google.com/googlenest/answer/9247132
