New 2 gen battery outdoor camera's wont charge to 100%
wmrose
Just purchased a two pack of the nest outdoor cameras from Lowes.  They are the 2 generation battery model.  Both cameras won't charge up to 100%.  I am using the original power chord and they are plugged in correctly.  The cameras are turned off and sitting in my office with the supplied chord.  I something wrong with the camera or the power supply?  One camera was pulled in all night and only came to 77% and the other I had pulled in all day yesterday and it came up to 66%.  What am I doing wrong?
aatienza
I appreciate the help, Brad.
Archie
aatienza
Hey wmrose,
Archie
