01-27-2025 11:17 PM
I didn't want to get involved with the Google Home App as I was perfectly fine with Nest, but I bought a V2 indoor wired camera to add to my family of V1 indoor and outdoor cameras. Everything had to be migrated to the Google Home App.
I installed my new camera. It worked at first, but then it stopped working. I factory reset the camera and did a re-install. It's working fine now.
The problem is that the old installed camera still sits in my list of cameras in the Google Home app.
There is no way to delete it. I go to DEVICES, press down on the camera I want to remove, and a blank page says INTERNAL ERROR (with ice cream cone) and I can't do anything. Pressing on the three vertical dots does nothing.
How does one remove a camera from the Google Home devices? Maybe the problem is that the same camera was renamed to another room on the second install.
01-28-2025 04:53 AM
Same problem. No solucion from Google
01-31-2025 10:23 AM
I also have the same situation.
02-01-2025 06:09 AM - edited 02-01-2025 06:11 AM
02-01-2025 02:11 PM
Same and still can’t get camera to stay connected and view on,y on the first 2 minutes after set up green light then goes to white no video just that ice cream cone error
