01-02-2023 08:17 AM
I had one of the three nest cameras go off line so I removed it from my room. Now I’m trying to reinstall it and I get no blue light to reconnect it???
01-06-2023 09:58 AM
01-06-2023 12:50 PM
Pretty sure I already tried that
01-11-2023 02:53 PM - edited 01-14-2023 02:58 PM
@Chansen thanks for getting back to us and for trying the suggested step. Let's go ahead and check other options here. To confirm, do you have the battery or wired type of Nest Camera? How far is the camera from the router? Are there devices or appliances (such as baby monitors, microwaves, cordless phones, etc.) near the camera?
Give these steps a try:
Keep us posted.
I appreciate the help, Brad.
01-14-2023 02:57 PM
Hi Chansen,
How's it going with your Nest Camera? We would appreciate it if you could share with us the information I’m asking above. Also, were you able to perform the steps I’m suggesting? We'd be glad to hear from you — We'd like to make sure everything is working.
01-17-2023 06:37 AM
Hey Chansen,
