No low battery notification
Dnixo
When my 2 outdoor cameras rundown on the battery I am not getting any notifications. Is this normal? It’s kind of a hassle to just routinely be running around checking the cameras or app.
David_K
Do you have the low battery notification enabled in the settings?
Have you tried uninstalling and reinstalling the Home app? You'll then be prompted to re-enable notifications and allow the "time sensitive" notifications.
aatienza
Hey Dnixo,
I'm dropping by to ensure that everything is covered here. I hope that sheds some light on the issue.
I appreciate the help, davidking.
Archie
janthadeus
Thanks for your help here, @David_K and @archie.
I want to check if you still need help. Don't hesitate to reach back if you do.
janthadeus
It's me again. We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
