No notifications or audio
Elliel
We have set to factory setting’s twice
all notifications and sound on both home and nest apps are on
still no notifications delivered
cannot heat doorbell on my iPhone
no audio either way
and no real help to assist
vwry frustrating
Just checking in on this thread and the activity on it. Looks like the form has been filled out, and you should hear from support soon. In the meantime, we'll leave this topic open for another 24 hours in case there are any follow-up questions or comments.
6 REPLIES 6
Elliel
We are done this twice and hadn’t resolved the issue
@Elliel
Please fill out this form, and a higher tier of support will reach out to you with next steps. Please let me know once you have filled out the form.
Elliel
it’s been submitted
@Elliel
Thank you for filling out the form. You should hear from support soon regarding this thread.
