No sound notifications on my phone when doorbell ring or motion
Debbons
My notifications no longer come play a sound on my phone. I see the banners in my notifications but sound does not alert me. All sounds options are turned on. Please help as I used to get sounds alerts.
also how do I change the notification sound on my iphone
@Debbons
You could try deleting and reinstalling the Google Home app. We had do do this with the Google Nest app on one of our iPhones when we quit getting sound notifications for our Nest Hello Doorbells.
Google Nest does not provide any options to configure notification sounds.
mon786
If you're not receiving sound notifications on your phone when your doorbell rings or detects motion, there are a few things you can check:
  1. Make sure that the notifications for your doorbell are enabled in the app. Check the settings in the app to ensure that you have enabled notifications for doorbell rings and motion detection.
  2. Check that the volume on your phone is turned up and not on silent mode. It's possible that you have accidentally turned down the volume on your phone or put it on silent mode.
  3. Check that your phone is not set to Do Not Disturb mode. This mode silences all notifications and may be preventing you from receiving sound notifications for your doorbell.
  4. If you have an iPhone, check that the notifications are set to "Sounds" instead of "None" or "Banner." You can check this in the Settings app under "Notifications."
  5. If none of these steps work, try restarting your phone and your doorbell. This may help to reset any issues that are preventing sound notifications from coming through.
  6. If the issue persists, contact the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or recommend a replacement if necessary.
You can download free moblie app on webteknohaber.
janthadeus
Checking in — have you tried the suggested steps provided by MplsCustomer and mon786? If so, how did it go? Let me know if you need more help.
I appreciate the help here, MplsCustomer and mon786!
janthadeus
Hey Debbons,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
janthadeus
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
