12-17-2022 12:05 PM
I had a Ring doorbell but when it died, decided to go with Nest. It’s installed but when I ring it, there’s no sound notification on my phone like I had with Ring. Is that not a feature? Thanks.
12-17-2022 01:31 PM - edited 12-17-2022 01:31 PM
You should get a standard iOS notification sound unless you've turned it off, but no "ringing" sound. You cannot configure the sound.
12-18-2022 08:28 AM
Thanks. I should’ve bought another Ring! I’ll not be recommending Nest! Makes doorbell pretty useless if you can’t hear doorbell inside the house 🥵
12-22-2022 10:39 AM
12-28-2022 09:07 PM
Hi AWDeLand,
Abi
12-31-2022 09:19 PM
Hello everyone,
Abi
