11-23-2021 03:24 PM
can you help?
Before you enable the Nest Cam, make sure that your Nest Hub Max is set up.
11-29-2021 12:18 PM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be, but I wanted to make sure that your issue was addressed. The QR Code can be found on the back of the device where it connects to the base. You can also find the QR Code on the packaging of the device. Most QR Codes are around the same area on most of the cameras around the back of it.
12-12-2021 08:11 PM
Hi Brad. I have Hub max. There is no QR code on the box or packaging.
12-14-2021 02:19 PM
I just got a new Hub Max - there is no QR code on the device or packaging. No QR code or setup code appears on the screen.
01-09-2022 01:51 PM
I have the same issue. A Nest Hub Max, purchased several weeks ago. It has no QR code at all. It does not display a QR code on the screen. The box and packaging has no QR code.
No QR Code with the Nest Hub Max
#nesthubmax
04-21-2022 06:52 PM
Hi Everyone,
If you're still having trouble setting up the camera on your Nest Hub Max, please give these steps a try:
Note: Download the Nest App to use all features. While finishing the setup of the Nest Cam the device will create a new network. This is not a Wi-Fi network, it is a Thread network that allows Nest devices to communicate with each other.
If the issue persists, feel free to submit another post and provide as many details as possible so that others can lend a hand. Hope this helps!
Alex
