01-18-2023 07:43 AM
How do I get my ‘offline’ battery back to work?
01-22-2023 05:41 PM
Hi Tiffanyjanmcgee,
Thanks for reaching out. Let’s check this — a few questions: what’s the status light of your doorbell? How far is the doorbell from the router? Is it plugged into a power outlet? Also, were there any changes to your Wi-Fi network?
01-25-2023 06:05 PM
01-26-2023 07:17 AM
Hi JT-
01-27-2023 03:03 PM
Hello everyone,
@Tiffanyjanmcgee how's it going with your Nest Doorbell? I'm dropping by to ensure that everything is covered here.
Give these steps a try:
I appreciate your response, JT.
01-31-2023 08:25 AM
I've been having the same issues. Already installed it 3 times and still dropped 6 hours later. How many times do we have to reinstall this d@#n camera. Seems like a waste. Somebody on their end needs to quit focusing on the previous solutions and come up with a software patch that allows the device to reconnect automatically should the router get unplugged or a temporary service outage occurs. It's getting ridiculous at this point. Literqlly, the option to automatically reconnect to a network is one of the Simplest functions in technology that even the oldest smartphone can accommodate!
02-03-2023 03:11 PM
Hi SynL,
Thanks for posting here in the Community and for sharing with us your same concern. Normally, reinstalling your Nest Cameras is not always the resolution. Sometimes, it's just losing connection to your Wi-Fi network due to the distance of your Nest Doorbell to your Wi-Fi router. Especially when there are walls blocking or sometimes the fluctuation of your Wi-Fi network. These type of instances can be solved by a simple restart to the Nest Doorbell and it'll reconnect automatically to your Wi-Fi router. You may also consider restarting your Wi-Fi network.
02-06-2023 04:24 PM
I appreciate the help, Emerson.
Archie
02-07-2023 06:38 PM
Hello there,
Archie
