Outdoor camera not detecting motion
SarahV
We have had our nest outdoor cameras for under a year and one of our cameras recently stopped detecting any motion. It will show us a live feed, but no motion detection. I have tried all of the troubleshooting with no change! Help!!
2hig
Same here. I had to do a factory reset the reconfigure but still have motion not picked up.   Very inconsistent performance across 4 houses, all with a variety of Google and Nest cams.  Now moving one home to professional hard wired cams to evaluate performance and cost.
EmersonB
Hello everyone,
@SarahV and @2hig aside from restarting your Nest Cameras, please check as well if both Do not disturb and Airplane mode features are not enabled on your mobile device and on your Nest Cameras.
I appreciate the help, Brad.
EmersonB
