10-17-2021 03:26 PM
New router In our home, now the nest cam stays offline....can't find anything in settings to change that.
10-18-2021 05:01 AM
I did just that, started from scratch and set up the device, thanks for the reply
10-18-2021 04:56 AM
Did you set the router up with the same SID and password? If not, you will have to reattach each device and start over or change network in the Google home app.
10-18-2021 05:01 AM
