Peeling Nest Doorbell Wired
LesterT_297
My Nest Hello Wired Doorbell has begun peeling
it also stops functioning when a guest presses the chime button; lose connectivity, no chime, or alert for a few seconds to a minute
I've also reset the doorbell and loss of connectivity still occurs when a guest presses the chime button.
The unit as working fine before.
The doorbell is located on front door with a cover above the front entry to prevent direct sunlight and rain from hitting it
2 REPLIES 2
Sorry to hear you're experiencing this, I can imagine this has been stressful for you. If you're seeking a replacement, please fill out this form. However, we do not offer replacements for parts. If your device is no longer under warranty, we cannot offer a replacement, We're sorry for the inconvenience.
We received your form! Thank you for filling it out. You will be continuing the conversation with a higher tier of support via email. This thread will be locked in 24 hours. Thank you for your patience.
