Pin stuck to mount
SamSa
Yesterday I've removed my Google doorbell from its mount to charge. After it fully charged I tried clicking it back on its mount but the camera doesn't click in the mount anymore. It seems that the upper pin (which is located right above the charging area) doesn't come out of the camera anymore and therefor doesn't click in its mount.
Is there a solution to get the pin out of the camera again?
Kind regards,
Sam
6 REPLIES 6
Mckinlayross
I also have this problem, did you find a fix?
Returned it to the store to repair. They said it was beyond repairing and received my money back.
I used a scalpel to prise it back out, seems to work now. Mechanical issues, probably due to water, weather
SamSa
No thanks, returned the Google product and bought a Ring doorbell.
Hey Folks.
